9800gx2 size
stevyd10
Please can someone clarify the actual size (length) of the 9800gx2 and also could you include if you measured the very full length including the i/o bracket or just the pcb. Thanks this will be really helpful as i know its going to be a tight fit but i just need to make sure it will actually fit.
(e-peen)2
It's the same size as the ultra 10.5 inches I remember reading somewhere - [H] review thread.
how bout width? same as an 8800GTS 512?
Yes. It is the same as the 8800GTS 512MB, 8800GTS 640MB and 8800GTX/Ultra cards give or take a few mm. Any case a 8800GTX will fit into a 9800GX2 will fit in just as well.
Yeah that is probably true. However I need to find some exact measurements because I literally have a few mm's of clearance on all sides in my Shuttle. I know an 8800GTX will fit as well as a 3870X2. Also would need to see measurements of the connectors coming out the top as there is very little space for the card alone, all the power connectors make it even more tricky. Depending on how exactly those connectors line up with the drive cage I either have ~5mm of clearance or ~40mm for the connectors.
Also I know this thing is going to be a power hog. If a 3870X2 and GTX can be used it seems plausible a GX2 should be as well. After all Shuttle PSU's are extremely efficient and capable of much more strenuous load than similarly rated ATX PSU's.
