I have a question please. In a single 9800GX2 card operation, can the user select 1 or 2 gpus to work, or does it scale gpu core usage automatically to the game or graphic program? I'm just curious.
Automatically it comes with 2 gpu's working in SLI so only one of the dvi ports works. Now if you want multi-monitor support you just have to turn that feature off.
