Aloha !
I recently purchased a whole new lots of parts for a new rig, but been having alot of troubles getting the 9800GX2 to run properly with Multi-GPU activated.
Anyway so when it's activated through the Nvidia Control Panel (using latest drivers), Windows Desktop runs fine, but as soon as you load up a 3d game, it starts to do massive flickering / blinking to the screen, at first it looks like some sort of vsync problem, but mucking around with those settings didn't fix it.
So I turned off multi-gpu and works fine!
Here is my rig -
PSU - Thermaltake Toughpower W0133 Cable Management 1200W (recommended by Nvidia)
Motherboard - Asus Striker II Extreme (Latest Drivers & Bios)
Graphics - XFX 9800GX2 (Latest Drivers with 6pin & 8pin connected correctly)
Ram - Asus DDR3 1333Mhz 2Ghz
Some people said it may be heat, so I installed RiverTuner and got the Graphics card down to 38deg.
The Graphics is running off 12V4 from the PSU.
Here are some Video Links -
www.members.iinet.net.au/~rathbone1/multigpu.zip
Now it's hard to spot the flickering on the menu screen, but it is happening, to see how bad it gets (when entering the game) I can go to the Video options.
www.members.iinet.net.au/~rathbone1/nomultigpu.zip
Here I am turning off multi-gpu, loading up a game again, no blinkering!
FRAPS could not detect the blinking while recording.
Any ideas ?
Cheers
Here is my rig -
Any ideas ?
Cheers
