I just did a clean install of Win 7 Ulti x64 last night, and figured I would give the 257.15 drivers a go....they have had improvements in all the games ive tried since then(specifically BFBC2, love lower load times, and able to hit 60+FPS on media all the time), however in MSI Afterburner I am now unable to see what my GPU usage is, every other graph still works.....this issue is present on stock, my OC setting(760Core/1900 Shader/1100 Memory, this is 100% stable, has been for a while), and on my power/heat saving setting(510 Core/1275 Shader/825 Memory, basically the lowest I can put all of the sliders....
any idea how to get it back, its not too worrying not to have it, but if one graph is off , i figure maybe another is, and my temp may be wrong, or another sensory/reader.
forgot to add, i did install/download the Win 7 x64 driver as well, so compatibility should not be an issue
