I was curious what other owners of this card have OCed to? I have the MSI 'RX9800PRO-TD128', which is the 9800 XT, which in turn is the 9800 Pro (Plus or something?) 128mb, 256bit
The default core/mem speeds are: 378/338 and it has a slightly bigger heatsink than the standard 9800 Pros: http://www.msicomputer.com/product/p_spec.asp?model=RX9800PRO-TD128&class=vga
I have 4 case fans and keep my side open, don't really use AC anymore since the heatwaves around here are done (Philly, PA)... case temp is usually ~50 deg celcius.
Any ideas what I could OC this to? Is using ATITool's 'Find Max' a good optimal setting?
