9800 Pro resolutions?
BoogerBomb
OK I just bought a new HDTV the Sony KDF-50WE655. Its native resoltion as I understand it is 1386 x 788. Can the 9800 Pro output this resolution so that I dont have parts of the desktop out of view of the monitor? I will be connecting it using a DVI to HDMI cable.
Nobody else seems to be responding so: I have a Radeon 9700 Pro using recent Catalysts which I assume is the same as a 9800 Pro. The closest I can come to your desired resolution is 1360 X 768.
Download 'PowerStrip' it will allow you to set your video card to any resolution you need.
