9800 Pro Question.
lil layzie
I'm just wondering what drivers are you using with your video card? ATI Cat's, Omega's, DNA, etc?
I have a Sapphire 9800 Pro and currently using Omega 3.9 drivers, but I might try out some other drivers if I see enough people using a certain one.
Use Omega 4.2 Driver. They are best by far though causing problems to someone.
i would suggest that you try the latest drivers from omega, dna, and cat and see for yourself which is the best. for me its the omega based 4.2
I've got two things to say here.....
1: I'm using the 3.9 Catalyst, the Omega's have always dropped my 3dmark scores and gamed a few FPS lower so I stick with the BBA drivers for my BBA card. ;)
2: Poison.....if THAT'S your sig then I'd REALLY suggest you shorten it up right away. The (very clear) forum rules and regulations state that you're aloud to have a maximum of a 10 line long signature. I'm sitting here looking at yours in 1280x1024 resolution and I still count a whopping 18. No hard feelings, I'm just getting to you now to save you from hearing it from a mod later on.
