9800 Pro Just Lost Color
sdk
Specs are in sig. At the time I am pretty shure that it was running at stock. I opened up CS and all of a sudden everything went darker, and all the graphix went all bad. Just like not as good as quality. I check settings and it was on 32 and 1280x1024. the cards fan was spinning, i have the card out rite now, it is kinda hot to the touch, i did try one reboot and still the same thing, so its out now
what could of happened? something fried? should I let it sit overnite? any ideas?
it seems that, it color starts low, then goes higher gradualy, like green will go to black, is this monitor or gfx?
NEW- a driver reinstall seemed to fix it, i put the 4.2s back on, if i uninstalled it then reinstalled it, that won't affect my install order rite?
