MrFace said:Is there a shim on the stock cooler? I want to apply Arctic Silver, but I dont know if the stock cooler has a shim or not
RancidWAnnaRIot said:it does.. but you shoudl be fine putting the AS5
Sometimes. Some 9800p cores are actually higher than the shim. Mine wasnt, so I just ground off the base of the heatsink, leaving a square to contact the GPU. I killed my first 9800pro by removing the shim, I swore I would never do it againMrFace said:But wouldn't removing the shim leave a space between the GPU and heat sink?
RancidWAnnaRIot said:wait wait wait... you were planning on removing the shim???? cuase don't!!! you might crush the GPU!!! don't remove the shim!
