erehwon6811
- Aug 5, 2004
I'm setting up a computer in my room to work as a HTPC. I have a 9800 Pro and a TV with component input. I found a DVI to Component cable that I would like to use to connect my computer to tv. The site has this message: (*)The Cable Not Support your Computer Monitor Video Port, or Y , Cr, Cb Video. Your Video Source Must Provide a YpbPr Component Video Signal form the DVI-I Video Ports to Use Cable. Does that mean I can't use it with my 9800 pro? If I can't, I'll use the svideo cable I picked up at good will for $1.5.[font=Verdana, Arial, Helvetica, sans-serif][font=Verdana, Arial, Helvetica, sans-serif]
[/font][/font]
[/font][/font]
