9800 pro 256 hangs up during games
I just built a new system. And my graphics card craps out on me during games.....All games. I've done everything correctly installing (Im pretty sure). I installed the VIA AGP driver..then the Catalyst driver.
It only does this during games, the rest of the time it is fine......I think it might be a temp problem?
I
Also...there is an aluminum plate over the heatsink...is this normal....All the ones I've seen have an open heatsink
HELP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Bought one of the OEM 9800 Pros, didn't ya. All I can suggest to to peel that hsf off and replace the thermal adhesive with some Arctic Silver 3. It'll help a little. You could also throw about 10 - 30 dollars on a new hsf for the card. I'd suggest the Arctic Cooler v2 or higher.
I can't understand why ATI doesn't throw a bigger hsf onto their cards. Especially since they run with higher clocks than Nvidia boards and look at Nvidia's hsf.
Oh...also check your case temps. Possibly some bad airflow going on.
Try checking your case temps first. Definitely don't want to void the cards warranty or ability to be returned, until it comes down to knowing that it's the cards problem.
Try opening up your case and blowing a fan directly into your case. If that doesn't work, if you can, test it in a different PC. If that doesn't work, try using older catalyst drivers. After that, peel that aluminium plate off. Still broken, pull the hsf off and throw some arctic silver 3/5 onto the gpu. Don't forget to pull scrap the thermal adhesive off. Throw the hsf back on. Still having issues, buy a whole new hsf for the card. Preferably copper, but the Arctic VGA cooler does a pretty good job.
After that all that, the card has been plenty voided and a return is impossible. If problems still persist, dump it onto ebay and give a short description of your problems and say the card is working. Set a price of $200 bucks and you'll probably be able to get that cash too. Then you can take that $200 bucks, wait for the Geforce 6600GT to come out and sit there looking pretty when it comes in and is installed.
Well....I opened up the case and had a fan blowing on the GPU....and I got to play for about 2 hours........Its definetly a cooling problem
I used to have the same problem back when i had a via PT800 chipset. set your agp speed at 4x insted of x8 and see if that fix it or try omega drivers.
Cause from what i've read in different forums via PT800 and PT880 doesnt get along with ATi video cards.
