9800 pro 128mb vs 256mb
ElvenRaider
How much does the extra ram really help. Also if anyone has come links to reviews that compare the two, I would like to read them.
i really wouldnt know since ive only tried 256mb, but ive heard that it barely makes a difference at all. but its suppost to be more "future proof" for future games that are coming out that will take more of a benifet from the extra 128mb.
I think the 256mb is a better investment for the future, however by the time it is needed the card will probably be pretty old anyway.
For the near future, 128mb should be fine.
128mb vs. 256mb depends on what resolutions that you run games at.
If you run res at around 1024x768, 128 is more than sufficient.
1600x1200 is where the 256mb comes in handy.
I'm planning on getting one when the next gen of cards come out. Which do you think would be the better one to buy. I'm thinking the 256 if it will play future games better because I like to keep a vid card as long as I can since they arn't exactly cheap.
