Noetic
- Apr 11, 2001
I have started folding with one as of today. Do I need to enter it as two separate boards with all the BS, or just one?
Ah....... nuts... Well, I will try to shoehorn the other 9800 GX2 sometime today. I have some work ahead of me.
Thank you for the info.
so im guessing you have 2 9800GX2's? you can fold on both of them as long as you disable SLI.. so you would have to run 4 gpu clients.. and like amd_gamer said.. if you are on vista.. you need to run dummy plugs on each DVI port.. then extend your desktop across all 4 displays.. and each card will fold.. if you are on xp then you dont have to worry about it..
If you have any problems let us know, there are a few of us have/have had rigs like yours.
There are a few tricks to getting it working and getting rid of all the heat.
I am still having fits regarding SMP with my dual opty 8346 rig. Instructions followed, but it refuses to work with my domain\computer entry.
Linux and GPU folding is not an option so, should I just run multiple FAH cpu instances, like the good old days?
Try this guide as it has helped a few people maximize their PpD with little to no effort.
You can certainly run Dual SMP clients (problamatic at best) or run 4 Classic Clients (stable, but much much lower in PpD).
If you want stability, yes.
I've heard things in the wind that we might see a SMP2 in the not so distant future (maybe before the end of the year) and they should have (most) things fixed for windows.
This may or may not come to pass, so run the standard ones for now.
They were referring to running the Linux SMP client within virtual machines, not within a native Linux installation. That's definitely worth a shot considering it'll give you much more PPD compared to the WinSMP client, especially on an 8-core machine.Linux and GPU folding is not an option so, should I just run multiple FAH cpu instances, like the good old days?
My point is that you can run the Linux SMP client within VMs while running Vista and not interfering with Windows at all. I use Vista on my main PC exclusively, but at the same time I run two Linux VMs in the background for F@H.I tried to elaborate in a later post. I would prefer to keep this a wholly Vista machine (It is my "do everything" machine. The wife permits me but one box..... and she must be able to use it as well.![]()
I'm just putting it out there so you're aware of the possibility. If you ever do decide to give it a shot, capreppy's guide is very straightforward and easy to follow as he's already pointed outFair enough, however it is bit beyond my present skill set. All in good time.
I'm just putting it out there so you're aware of the possibility. If you ever do decide to give it a shot, capreppy's guide is very straightforward and easy to follow as he's already pointed out.
I had a feeling, which was why I was being so persistentHonestly, I had not read his link. I assumed the reference full VMWare. My mistake.
Did you extend your desktop? Or were you not able to?
It was a booting issue. I have the one card up, split and fully folding... Now for the other.
86 degree C with 100% fan..... yeesh. I might have to down clock.
