9800 GX2, Multiple monitors, and Mulit-GPU mode
johngvo
HI all,
I have a 9800 GX2 driving a 30" Dell and a 24" Dell. In the Nvidia control panel, I have to select "Multi-display mode" in order to use the second monitor. However, underneath that option, there is a section that asks me to "Select the display to view multi-GPU rendered content on." Naturally, I select my primary monitor (30").
My question is this, when I play games, full-screen, does the GX2 automatically switch to "SLI" mode where it utilizes both GPUs or do I need to go into the control panel each time and switch it to Multi-GPU mode? I figure I got the 9800GX2 just so that I can get the benefits of SLI without actually buying two cards, and more importantly, to still be able to use multiple monitors.
Nevermind, I found out the answer. If I have to switch to Multi-GPU mode if I want to take advantage of the SLI features of this card, which then disables my second monitor. I can still play Crysis at 1920x1200 res on High. It's a little jerky so I may drop some settings down to Medium to see if it plays better.
