I recently got a second 980 TI (same as first: EVGA Classified) to mine with and also to SLI with when appropriate. I normally mine on it while I game on the other GPU. I noticed that I am unable to get the clock to go over 3305, while GPU 1 is running at 4001. After researching I realized that GPU 2 is stuck in Pstate 2, a lower power state used for compute. The only way I've found to get the memory higher is to use Nvidia Inspector to manually overclock the P2 state, but then it maxes at 3725, and this is still less than ideal.
I tried going thru http://cryptomining-blog.com/tag/nvidia-force-power-state/. Was fun re-learning how to navigate using DOS but manually changing the clock speeds was rejected as not having administrator permissions. I'm the only user.
Any ideas?
P.S. Using MSI Afterburner to OC.
Any ideas?
