975X Motherboard considerations
Banya
Looking for a little bit of advice, I'm in the process of putting together a new C2D system.
What I've got picked out so far:
E6400
1gb Mushkin DDR2 800
Sapphire X1950 Pro 256mb
Now comes the issue of the motherboard. I was fairly certain about the P5B Deluxe, until I found out that it can't do Crossfire with the X1950 pro. (doesn't work with internal peer-peer crossfire)
There seems to be a lot less selection for 975X boards, at least in terms of stable OCers. I'm hoping to hit around 400FSB, nothing TOO extreme. I did look into the MSI and DFI options, but they seem to have tons of problems, so I guess I'm down to either the P5W-DH or the Bad Axe 2. Should I go with one of these, or are there some other options I haven't thought of?
also worth looking at the abit AW9D series.
So far the Bad Axe boards, Asus, and DFi's I have used and all were good. Bad Axe was the most stable and very painless to work with.
I hadn't really checked into those too much, but now that you mention it, the regular AW9D (non-max) is around $190. Newegg doesn't seem to carry it. Any other reputable dealers you recommend?
i think for E6400 a mobo with 965 chipset will be better since they offer higher FSB then 975X chipset. so, i would say go with Asus p5b delux. :)
my dfi 975x had alot of bugs. was very pickey about ram and also has some difficulties with some PSU's. it also was a struggle to get beyond 400fsb overclocking wise . i sent it back and got a intel 975xbx which was much better and overclocked well after the unlocking mod .
i haven't run the MSI however i don't see how it could be any more flakey than the DFI i had .
i would say the best bet would be the intel 975xbx or xbx-2 .
i haven't run the asus p5w975x --but there alot of folks that really like it. i figure it's a good mb as well. :cool:
I'd get the P5W DH over the XBX myself (in fact, I did :) ). I read somewhere that the XBX was a pain to OC simply because all failed OC's needed to be cleared via CMOS jumper as opposed to reseting itself.
The XBX and P5W are usually about the same price. The features are better on the P5W.
With a 6300/6400, I'd get a P5B-E instead though for some high FSB OCing.
Thanks for the input guys. I finally decided to go with the Asus P5W.
Tankguys had it for $209 ($220 shipped)
