BadAssSaturn
- Jul 2, 2003
Anyone here have a Radeon 9700Pro? What kind of 3d mark scores are you getting? Let me know
Originally posted by MemoryInAGarden
I've gotten nearly 18k in 01 and a little over 5k in 03.
Nah, seems about right for that card. Mine does about 4750 stock in '03, set at default settings.375/335. My 03 score does seem screwy but I don't really care.
I said default settings (as in default clock speeds, not overclocked), not default benchmark.I would have expected him to get higher, my 9600xt gets 4792 in 03 (default benchmark since I don't care to buy it).
Compared to similar processor speeds and stock GPU clock speeds (as with my 9700) on 9700 Pro cards, the top scores all fall pretty close to 4750.
As evidenced Here
Hence, my determination that his score of a little over 5k in 03 , was probably about right for that card.
No doubt about it, the 9600 XT is a real good card. Not at all hard to believe hitting 9700 stock scores though. The 9500's can hit those speeds too, with a bit of tweaking.I still would have expected higher. But I've never had/used a 9700pro either...maybe I'm expecting too much. Because even with my 9600xt o/c'd I still would'nt expect it to match the stock performance of a 9700pro (due to the whole 8-pipe/256-bit vs 4-pipe/128bit architecture)
Originally posted by Papa Smurf
I run a AMD Athlon 1700+ 1.47 oc/ed to 1.65 w/ 512MB PC-2100 and a Powercolor 9700Pro. However, I'm only getting like an 11500 in 01. Do you guys think that is normal, or do I need to try doing some things to boost the scores?
Originally posted by Semose
I have an ATi Radeon 9700 AiW Pro, and I get a score of around 2850 in '03. This is due to 256mb PC2100 generic RAM, motherboard with max 4x AGP, and an AMD Athlon XP 1600+ OCed to 1568Mhz.
Oh , and the card was OCed to 395 Core and 350 Memory at the time of the benchmarking, but I've been told by my friend, the owner of www.extreme-pc.ca (who is really buddy buddy with ATi and goes to many conferences) that OCing a locked Radeon 9700 PRO such as mine will mess up the RAMDAC and kill the card after 3 months. Since it is my memory, mobo, and CPU holding back the video card, I have no reason to OC it.
But has anyone else heard of killing a locked card by OCing it? By that, I mean resetting the Core and Memory speeds after every boot (done automaticaly by ATITool). My friend also told me that if you flash the BIOS of a locked PRO with a hacked one, and you screw up, it completely screws up the card, and ATi will not replace it. Can anyone confirm or deny this?
Originally posted by xenogears
You are looking at it the wrong way though. Default benchmark is run at 1024X768 res with no aa/af on. Try upping the res and adding aa/af to the benchmark or any game and the 9700pro will distance itself from the 9600XT by quite a bit. My 9700np only gets 4440 in 3dmark 2003, but I play all my games at 1280X960 res with 4x aa and 16x af.
Originally posted by ATi_Loyalist
havent benched at 437 yet, but in 2k1 at 374 335 i was getting about 18,100 ish. 3dmark03 with same speeds, was about 5600
Here's another scenario to chew on.
My friend is running a 2.6P4 OCed @ 3.2 right now. He's using Geil PC3500 Ultra Series Ram, SATA, and running a ATI 9600XT, but he's only pulling a 12500 in '01. That gives? I would have though he would be running 15k or more.
