9700 pro heatsink
0ctinium
i am about to take the stock heatsink off of my 9700 pro to put some as5 and was wondering if i was in store for any surprises. if i remove the clips does it easily come off? what is the best way to remove the heatsink compound already there (especially on the die itself). thanks a bunch :)
(btw how much of a boost should i expect by doing this?)
edit: i was just reading some stuff from 9700 pro overclockers and apparently if you take off the heatsink you MUST remove the shim. this is because the thermal pad that is usually there fills the gap that the shim creates....and a thin layer of arctic silver cant fill that. any truth to this?
You could pry off the shim but then you risk crushing the die on the gpu.
If you are careful though you shouldn't have any trouble.
Yes there is truth to it, the shim sits very very slightly higher then the core....the pad that ATI uses is awful, but thick enough to make good contact. If you remove that pad, which you are, you will need to remove the shim or the heatsink will not touch the core unless you use the same amount of AS as thick as the pad was..which would be MESSY and too much to. Just remove the shim carefully and save it in a box.
