9700 pro for doom3 ok?
pieter3d
Will the system in my sig be able to render doom3 smoothly while still looking awesome or do you think I will have to sacrifice significant image quality?
Medium quality (some texture maps are compressed) at 800x600x32 will probably be alright. Might have to go 640x480 to keep it fairly smooth in big firefights.
depends on your standards for good graphics. I suppose if you never see it in it's glory then you will be ok, it's when I take peeks at high res screenshots with high quality settings that makes me want to get something faster/better.
you should be ok, just don't go looking at screenshots.
if you want to see doom3 in its fully glory you are out of luck. this applies to EVERYONE IN THE WORLD
You should have no problem. 1024x768 is a certainty if you go by the pre-release benchmarks.... additional AA is not so certain
I would think that 1024x768 w/o AA and AF would be possible.
if not higher. People need to relax. This is an Id game... remember? Sure the requirements are high, but come on.... the game scales.
Breathe IN.....DEEPLY....
Let it OUT..... GOOD....
RELAX.
