9700 power cable question....
dohcmark8
If my computer dont have a floppy drive, can I use the floppy power cable that comes directly from the PSU to power the 9700?.
Hi,
Yes you can. Usually on some PSU's, there should be more than one floppy connector. I had two on mine. Doesn't matter what floppy connector you used. It's all the same.
-Thanks
