morfinx said:I heard WMV HD acceleration is broken on 6 series, is that true?
Sir-Fragalot said:Sort of. There is a fix for it found on the Microsoft web site. It's called the Purevideo fix.
To answer the original posters question: No. The Geforce 6 and 7 series and the ATi X1k series are the only ones to have such acceleration.
PureVideo is a collective name for several features, including WMV9/WMV9 HD/MPEG-2 decoding, HQ scaling, adaptive de-interlacing, etc. http://www.nvidia.com/page/purevideo.html The NV40 has a partially broken VPU that doesn't work for full WMV9 HD decoding acceleration. The NV45 is just a NV40 + an on package AGP to PCI-E bridge, so it also has the same problem.morfinx said:I did a search and seems like people are saying 6 series cards based on NV40 core do not work with Purevideo
pxc said:PureVideo is a collective name for several features, including WMV9/WMV9 HD/MPEG-2 decoding, HQ scaling, adaptive de-interlacing, etc. http://www.nvidia.com/page/purevideo.html The NV40 has a partially broken VPU that doesn't work for full WMV9 HD decoding acceleration. The NV45 is just a NV40 + an on package AGP to PCI-E bridge, so it also has the same problem.
The PCI-E 6800 GS uses the NV42 GPU, which doesn't have the WMV9 HD problem. The NV41, NV43, NV44 or NV44A chips also have properly working VPUs. The AGP 6800 GS currently uses the NV40 core.
http://support.microsoft.com/default.aspx?scid=kb;en-us;888656 is the WMP10 patch.
"The NV40 has a partially broken VPU that doesn't work for full WMV9 HD decoding acceleration."morfinx said:What do you mean NV40 is partially broken?
pxc said:"The NV40 has a partially broken VPU that doesn't work for full WMV9 HD decoding acceleration."That pretty much explains it.
This page shows relative NV40 (6800U) vs R480 (X850 XT PE). The R420 should have similar decoding performance: http://www.xbitlabs.com/articles/video/display/radeon-x1000_38.html There's not a huge difference between those two if you. Both support DXVA and both will smoothly play 1080p WMV HD on an Athlon 2.4GHz (what xbits used). xbits didn't seem to use the nvidia dvd decoder, so MPEG-2 decoding is higher than it could have been.
