9600XT + Iceberq mosfet
Mijae
I was going to put some of the mosfets that come with the iceberq package, and then I realized that they are twice as long as the ram on the video card, so my quesion is does it really matter? Or should I use my dremel to cut each mosfet to fit the ram perfectly? Or it doesnt matter if the mosfet is too long?
Also, I dont think copper is hard to dremel right? :p
first of all, they are ramsinks, mosfets are voltage regulators.
and the ramsinks that came with the iceberq are aluminum, not copper, and it dosnt matter if they are bigger...
but if they interfere with components on the card, then you could dremel the sinks, since i dont think its hard to dremel aluminum at all.
Actually they have an Iceberq with all copper heatsinks and one with aluminum.
i thought the all copper one only had 2 sinks...
one with a fan and one without.
the iceberq 4 has some copper colored aluminum ramsinks.
Sorry about the mosfet/ramsink thing, I got it wrong :p And yes, I got 8 copper ramsinks.
I think I'll just stick them as they are...
