9600XT Cooling Solutions?
BadBoy_77
hey guys new here to hard forum as you can see. just got a 9600XT Built by ATI and looking for a better cooling solution. something that is worth the money but don't want to go broke. any suggestions?
unless you're going to voltmod, stay stock cooling (at best just use artic silver on it). If you wanna do some voltmodding then you cna get the artic coolers or 1u's
I have the stock cooler and put AS3 on it and my temps are 37C. And that's damn good.
Although, i had to put new pins on the cooler to hold it on and they're shorter than the ones on it originally, so it is incredibly tight against the processor.
