The 970 is a year older but obviously more powerful. Not sure if the 960 with 4GB fixed the 3.5 + 5 issue.
The 960 is touted as playable at 1080 although reviews show this is not the case with newer games maxed out.
I have a 32" 1440 monitor but must play at 1080 with my 750ti.
I notice the Gigabyte blower 970 dropped in price as is only 80 bucks more then the 960 4GB.
Sounds like a no brainer?
Just wish it was not 10.5 inches long, damn.
It will fit in my Lian li case without issue but block the sata ports, not that I switch the cables around often if at all so not a real deal breaker.
No reviews on the blower version yet but if it can do 25% less heat then reference according to Gigabyte it should run pretty cool, like 140F range.
The 20 MIR right now helps a bit if you get it too.
Is the 960 "good enough" or just go with something that has more future breathing room [until Pascal]?
