955 Deneb and overclocking.
FrEaKy
[H] Movie and TV Show Review Guy
So my 955 Deneb needs a little push, stock running at 3.2GHz, I didnt get into alot of OC options with my BIOS, but I did try an auto overclock function on the bios which did a 5% push to 3.35 and its running very smooth. Still at 45C with the H50 temp wise under full load, not bad.
So, what should I go for OC wise, what mp's and whatnot. Any ideas? Motherboard for reference is a ASUS M4A785TD-V EVO
well its a black edition processor so that makes it much easier to overclock.. since you are running an H50.. i would say try bumping the cpu voltage to 1.45v then bump the multiplier from 16x to 18x which will give you 3.6ghz then run intel burn test for about 10 runs.. make sure its stable.. check your temps.. then try bumping it to 19x with the 1.45v which will give you 3.8ghz.. most likely it wont be stable but its worth trying.. if your temps look good with the voltage at 1.45v (under 60C) then try bumping the voltage to 1.48v with the multiplier at 19x.. if you have a 955 C3 stepping you could probably do 3.8ghz some where between 1.45v and 1.5v if its a C2 stepping then you might have to go a little over 1.5v to keep it stable for running A3 WU's..
the safe voltage max is 1.55v the thermal temp on the 955 is 62C.
other then changing the cpu multiplier and cpu voltage you shouldnt have to mess with anything else unless you really want to..
I suspect that you should be able to hit anywhere between 3.6 - 3.8ghz just fine from what i've seen with others overclocking these 955/965's. I'm not taking mine past 3.5ghz as the stock cooler gets so incredibly loud and starts to sound like a leaf blower.
lol go spend 30-40 bucks and get an s1283 heatsink.. should easily hit 3.8ghz.. hell you can probably find a sunbeam core contact for less then 30 bucks and its about on par with the s1283 on AMD processors..
With the h50 mine just hit 3.82 at 18 MP and 1.45v
Not bad..... Its running smooth and Burn In turned up nothing. I went ahead and started up F@H, lets see how she goes (OH and 55C under load)
Except I cant seem to download any cores for some reason.
COOOOOODE
Code:
Note: Please read the license agreement (Folding@home-Win32-x86.exe -license). F
urther
use of this software requires that you have read and accepted this agreement.
4 cores detected
If you see this twice, MPI is working
--- Opening Log file [June 5 05:21:50 UTC]
# Windows SMP Console Edition #################################################
                       Folding@Home Client Version 6.29
                          http://folding.stanford.edu
Launch directory: C:\Program Files (x86)\Folding@Home Windows SMP Client V1.01
Executable: C:\Program Files (x86)\Folding@Home Windows SMP Client V1.01\Folding
@home-Win32-x86.exe
Arguments: -smp -advmethods
[05:21:50] - Ask before connecting: No
[05:21:50] - User name: FrEaKy (Team 33)
[05:21:50] - User ID: xxxxxxxxxxxxxxxxxxx
[05:21:50] - Machine ID: 1
[05:21:50]
[05:21:50] Loaded queue successfully.
[05:21:50]
[05:21:50] + Processing work unit
[05:21:50] Core required: FahCore_a3.exe
[05:21:50] Core not found.
[05:21:50] - Core is not present or corrupted.
[05:21:50] - Attempting to download new core...
[05:21:50] + Downloading new core: FahCore_a3.exe
[05:21:51] + 10240 bytes downloaded
[05:21:51] + 20480 bytes downloaded
[05:21:51] + 30720 bytes downloaded
[05:21:52] + 40960 bytes downloaded
[05:21:52] + 51200 bytes downloaded
[05:21:52] + 61440 bytes downloaded
[05:21:52] + 71680 bytes downloaded
[05:21:52] + 81920 bytes downloaded
[05:21:52] + 92160 bytes downloaded
[05:21:52] + 102400 bytes downloaded
[05:21:52] + 112640 bytes downloaded
[05:21:52] + 122880 bytes downloaded
[05:21:52] + 133120 bytes downloaded
[05:21:52] + 143360 bytes downloaded
[05:21:52] + 153600 bytes downloaded
[05:21:52] + 163840 bytes downloaded
[05:21:52] + 174080 bytes downloaded
[05:21:52] + 184320 bytes downloaded
[05:21:52] + 194560 bytes downloaded
[05:21:52] + 204800 bytes downloaded
[05:21:52] + 215040 bytes downloaded
[05:21:52] + 225280 bytes downloaded
[05:21:52] + 235520 bytes downloaded
[05:21:52] + 245760 bytes downloaded
[05:21:52] + 256000 bytes downloaded
[05:21:52] + 266240 bytes downloaded
[05:21:52] + 276480 bytes downloaded
[05:21:52] + 286720 bytes downloaded
[05:21:52] + 296960 bytes downloaded
[05:21:52] + 307200 bytes downloaded
[05:21:52] + 317440 bytes downloaded
[05:21:52] + 327680 bytes downloaded
[05:21:52] + 337920 bytes downloaded
[05:21:52] + 348160 bytes downloaded
[05:21:52] + 358400 bytes downloaded
[05:21:52] + 368640 bytes downloaded
[05:21:52] + 378880 bytes downloaded
[05:21:52] + 389120 bytes downloaded
[05:21:52] + 399360 bytes downloaded
[05:21:52] + 409600 bytes downloaded
[05:21:52] + 419840 bytes downloaded
[05:21:52] + 430080 bytes downloaded
[05:21:52] + 440320 bytes downloaded
[05:21:52] + 450560 bytes downloaded
[05:21:52] + 460800 bytes downloaded
[05:21:52] + 471040 bytes downloaded
[05:21:52] + 481280 bytes downloaded
[05:21:52] + 491520 bytes downloaded
[05:21:52] + 501760 bytes downloaded
[05:21:52] + 512000 bytes downloaded
[05:21:52] + 522240 bytes downloaded
[05:21:52] + 532480 bytes downloaded
[05:21:52] + 542720 bytes downloaded
[05:21:52] + 552960 bytes downloaded
[05:21:52] + 563200 bytes downloaded
[05:21:52] + 573440 bytes downloaded
[05:21:52] + 583680 bytes downloaded
[05:21:52] + 593920 bytes downloaded
[05:21:52] + 604160 bytes downloaded
[05:21:53] + 614400 bytes downloaded
[05:21:53] + 624640 bytes downloaded
[05:21:53] + 634880 bytes downloaded
[05:21:53] + 645120 bytes downloaded
[05:21:53] + 655360 bytes downloaded
[05:21:53] + 665600 bytes downloaded
[05:21:53] + 675840 bytes downloaded
[05:21:53] + 686080 bytes downloaded
[05:21:53] + 696320 bytes downloaded
[05:21:53] + 706560 bytes downloaded
[05:21:53] + 716800 bytes downloaded
[05:21:53] + 727040 bytes downloaded
[05:21:53] + 737280 bytes downloaded
[05:21:53] + 747520 bytes downloaded
[05:21:53] + 757760 bytes downloaded
[05:21:53] + 768000 bytes downloaded
[05:21:53] + 778240 bytes downloaded
[05:21:53] + 788480 bytes downloaded
[05:21:53] + 798720 bytes downloaded
[05:21:53] + 808960 bytes downloaded
[05:21:53] + 819200 bytes downloaded
[05:21:53] + 829440 bytes downloaded
[05:21:53] + 839680 bytes downloaded
[05:21:53] + 849920 bytes downloaded
[05:21:53] + 860160 bytes downloaded
[05:21:53] + 870400 bytes downloaded
[05:21:53] + 880640 bytes downloaded
[05:21:53] + 890880 bytes downloaded
[05:21:53] + 901120 bytes downloaded
[05:21:53] + 911360 bytes downloaded
[05:21:53] + 921600 bytes downloaded
[05:21:53] + 931840 bytes downloaded
[05:21:53] + 942080 bytes downloaded
[05:21:53] + 952320 bytes downloaded
[05:21:53] + 962560 bytes downloaded
[05:21:53] + 972800 bytes downloaded
[05:21:53] + 983040 bytes downloaded
[05:21:53] + 993280 bytes downloaded
[05:21:53] + 1003520 bytes downloaded
[05:21:53] + 1013760 bytes downloaded
[05:21:53] + 1024000 bytes downloaded
[05:21:53] + 1034240 bytes downloaded
[05:21:53] + 1044480 bytes downloaded
[05:21:53] + 1054720 bytes downloaded
[05:21:53] + 1064960 bytes downloaded
[05:21:53] + 1075200 bytes downloaded
[05:21:53] + 1085440 bytes downloaded
[05:21:53] + 1095680 bytes downloaded
[05:21:53] + 1105920 bytes downloaded
[05:21:53] + 1116160 bytes downloaded
[05:21:53] + 1126400 bytes downloaded
[05:21:53] + 1136640 bytes downloaded
[05:21:53] + 1146880 bytes downloaded
[05:21:53] + 1157120 bytes downloaded
[05:21:53] + 1167360 bytes downloaded
[05:21:53] + 1177600 bytes downloaded
[05:21:53] + 1187840 bytes downloaded
[05:21:53] + 1198080 bytes downloaded
[05:21:53] + 1208320 bytes downloaded
[05:21:53] + 1218560 bytes downloaded
[05:21:53] + 1228800 bytes downloaded
[05:21:53] + 1239040 bytes downloaded
[05:21:53] + 1249280 bytes downloaded
[05:21:53] + 1259520 bytes downloaded
[05:21:53] + 1269760 bytes downloaded
[05:21:53] + 1280000 bytes downloaded
[05:21:53] + 1290240 bytes downloaded
[05:21:53] + 1300480 bytes downloaded
[05:21:53] + 1310720 bytes downloaded
[05:21:53] + 1320960 bytes downloaded
[05:21:53] + 1331200 bytes downloaded
[05:21:53] + 1341440 bytes downloaded
[05:21:53] + 1351680 bytes downloaded
[05:21:53] + 1361920 bytes downloaded
[05:21:53] + 1372160 bytes downloaded
[05:21:53] + 1382400 bytes downloaded
[05:21:53] + 1392640 bytes downloaded
[05:21:53] + 1402880 bytes downloaded
[05:21:53] + 1413120 bytes downloaded
[05:21:53] + 1423360 bytes downloaded
[05:21:53] + 1433600 bytes downloaded
[05:21:53] + 1443840 bytes downloaded
[05:21:53] + 1454080 bytes downloaded
[05:21:53] + 1464320 bytes downloaded
[05:21:53] + 1474560 bytes downloaded
[05:21:53] + 1484800 bytes downloaded
[05:21:53] + 1495040 bytes downloaded
[05:21:53] + 1505280 bytes downloaded
[05:21:53] + 1515520 bytes downloaded
[05:21:53] + 1525760 bytes downloaded
[05:21:53] + 1536000 bytes downloaded
[05:21:53] + 1546240 bytes downloaded
[05:21:53] + 1556480 bytes downloaded
[05:21:53] + 1566720 bytes downloaded
[05:21:53] + 1576960 bytes downloaded
[05:21:53] + 1587200 bytes downloaded
[05:21:53] + 1597440 bytes downloaded
[05:21:53] + 1607680 bytes downloaded
[05:21:53] + 1617920 bytes downloaded
[05:21:53] + 1628160 bytes downloaded
[05:21:53] + 1638400 bytes downloaded
[05:21:53] + 1648640 bytes downloaded
[05:21:53] + 1658880 bytes downloaded
[05:21:53] + 1669120 bytes downloaded
[05:21:53] + 1679360 bytes downloaded
[05:21:53] + 1689600 bytes downloaded
[05:21:53] + 1699840 bytes downloaded
[05:21:53] + 1710080 bytes downloaded
[05:21:53] + 1720320 bytes downloaded
[05:21:53] + 1730560 bytes downloaded
[05:21:53] + 1740800 bytes downloaded
[05:21:53] + 1751040 bytes downloaded
[05:21:53] + 1761280 bytes downloaded
[05:21:53] + 1771520 bytes downloaded
[05:21:53] + 1781760 bytes downloaded
[05:21:53] + 1792000 bytes downloaded
[05:21:53] + 1802240 bytes downloaded
[05:21:53] + 1812480 bytes downloaded
[05:21:53] + 1822720 bytes downloaded
[05:21:53] + 1832960 bytes downloaded
[05:21:53] + 1843200 bytes downloaded
[05:21:53] + 1853440 bytes downloaded
[05:21:53] + 1863680 bytes downloaded
[05:21:53] + 1873920 bytes downloaded
[05:21:53] + 1884160 bytes downloaded
[05:21:53] + 1894400 bytes downloaded
[05:21:53] + 1904640 bytes downloaded
[05:21:53] + 1914880 bytes downloaded
[05:21:53] + 1925120 bytes downloaded
[05:21:53] + 1935360 bytes downloaded
[05:21:53] + 1945600 bytes downloaded
[05:21:53] + 1955840 bytes downloaded
[05:21:53] + 1966080 bytes downloaded
[05:21:53] + 1976320 bytes downloaded
[05:21:53] + 1986560 bytes downloaded
[05:21:53] + 1996800 bytes downloaded
[05:21:54] + 2007040 bytes downloaded
[05:21:54] + 2017280 bytes downloaded
[05:21:54] + 2027520 bytes downloaded
[05:21:54] + 2037760 bytes downloaded
[05:21:54] + 2048000 bytes downloaded
[05:21:54] + 2058240 bytes downloaded
[05:21:54] + 2068480 bytes downloaded
[05:21:54] + 2078720 bytes downloaded
[05:21:54] + 2088960 bytes downloaded
[05:21:54] + 2099200 bytes downloaded
[05:21:54] + 2109440 bytes downloaded
[05:21:54] + 2119680 bytes downloaded
[05:21:54] + 2129920 bytes downloaded
[05:21:54] + 2140160 bytes downloaded
[05:21:54] + 2150400 bytes downloaded
[05:21:54] + 2160640 bytes downloaded
[05:21:54] + 2170880 bytes downloaded
[05:21:54] + 2181120 bytes downloaded
[05:21:54] + 2191360 bytes downloaded
[05:21:54] + 2201600 bytes downloaded
[05:21:54] + 2211840 bytes downloaded
[05:21:54] + 2222080 bytes downloaded
[05:21:54] + 2232320 bytes downloaded
[05:21:54] + 2242560 bytes downloaded
[05:21:54] + 2252800 bytes downloaded
[05:21:54] + 2263040 bytes downloaded
[05:21:54] + 2273280 bytes downloaded
[05:21:54] + 2283520 bytes downloaded
[05:21:54] + 2293760 bytes downloaded
[05:21:54] + 2304000 bytes downloaded
[05:21:54] + 2314240 bytes downloaded
[05:21:54] + 2324480 bytes downloaded
[05:21:54] + 2334720 bytes downloaded
[05:21:54] + 2338814 bytes downloaded
[05:21:54] Verifying core Core_a3.fah...
[05:21:54] Signature is VALID
[05:21:54]
[05:21:54] Trying to unzip core FahCore_a3.exe
[05:21:54] - Couldn't open file FahCore_a3.exe
[05:21:54] + Error: Could not extract core
[05:21:54] + Core download error (#2), waiting before retry...
wow if its stable at 1.45v i highly recommend trying to take it up higher.. you should be able to hold 3.9-4ghz.. some where near 1.5v maybe a tad higher..
if you need the core let me know and ill just upload it some where for you..
Its downloading the core fine, it just cant seem to open it.
I thought about pulling out the stops and going with a Noctua NHD-14, but realized it would be a waste of money since the gaming rig wouldn't be folding very often. My gaming rig is primarily brought online to play games, and games don't get these cpus very hot anyway.The stock cooler works well, just the noise is obnoxious as I can hear it running from downstairs when it spins past 5000rpms.
I have been considering switching to a H50, or even just picking up a Koolance block to work with my EXOS that is just sitting here...I would then have a nice TT120 with a custom bracket I'd be willing to let go cheeeeap for a fellow F@H'er :)
Thanks for the offer, but the TT120 would not fit as I am using all 4 ram slots on my motherboard. The only cpu coolers I am aware of that allow you to use all 4 slots are the Noctua ND-H14, NHD-12 SE2, and possibly the Coolermaster V8 :(
I'd be surprised..I have filled all 4 of my ram slots (MB in sig) with Corsair Dominator and they clear just fine...you just have to remove DIMMs 2-3 before you can remove the one closest to the cpu socket...
Ive got a 955, 1.4v @ 3709mhz, Cooled with a Freezer 7 rev 2 in a fractal r2 with all the fan mounts full of fractal fans bar the bottom intake by the psu..
running linx 0.6.4 at the moment as its the hottest day of the year, and its getting as high as 69c :( been dropping the cpu voltage, as started at 1.45, so the voltage drop has gained me 1c at max, it flucturates, but I cant see it throttle like I have done in the past, just the load flucturates instead. Any other ideas how I can get it to run a bit cooler? Already using AS5 on it as well. Disabled cool and quiet and all the fan control options in the bios already
Considering a H50 for it sometime in the future now...
darn if you had said this 3 weeks ago id be all over it but now that im planning to move i cant spend anymore money :(
