9500pro -> 9700 pro scam?
GTPoompt
I was looking for 9700 pro's on ebay and here comes an auction of a guy trying to sell a 9500pro which he claims is bios modded to a 9700pro...
here's link : http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=40158&item=5170467198&rd=1
(hope ebay is allowed)
Now looking at his card, I notice the memory is in the I shaped format, thus it only has the 128 bit bus... and second, i didn't think you could flash the 9500 pro into anything anyway, just the plain old 9500 and the 9800 SE.
So is this a scam?
I'm not planning on bidding or anything, just wondering.
EDIT: his english is not very good, but I'm not implying anything by that
yeah the "I" memory only has a 4 layer PCB IIRC. It takes a 6 layer "L" to make a 9500-9700 pro
As far as I know, you are correct. Only the 9500NPs with the L-shaped RAM configuration could be flashed into 9700s.
...a used ATI Radeon 9500 PRO 128MB video card; it is flashed to a 9700 pro so overclocking is enable(d)!
I think he is referring to the fact that all R300s except the 97Pro had their frequencies locked in BIOS.
i thought r9500pros could only be flashed into 9700 non-pro.
so then with the R300 core you couldn't overclock unless it was flashed to the 97pro bios?
Right, or a hacked BIOS from the same card.
http://www.xbitlabs.com/news/video/display/news6145.html
Edit: 9500Pro can't be flashed into anything else. It already has eight pipes enabled, and you can't flash a 128-bit memory bus into 256-bits. The basic 9500 128MB could be flashed into a 9700-class card, since it only needed its four pipes reenabled. The 256-bit bus was already there.
(Interesting that theoretically, the 9500 could have beaten the Pro in bandwidth-sensitive tests!)
the guy is an idiot. he can't even spell "Confidence"
he says "CONFIDENTS!!!"
