9500 pro mod/oc questions
CoolHand
got an 9500 pro comin from ebay, plan to mod/oc the bejebus outa it, but researching is giving me mixed answers on if i have to flash the bios or not to oc the thing, do i have to flash to oc if using the omega drivers? any amaizing overclocks to report...i thought this would be a more fun and cheaper way to replace my gf2 than buying an mid level card like a 9600xt or 5700.... any insight would be appreseated.
if your going to use the Omegas(good choice BTW ;) ) you wont need to flash the BIOS on the card. or at least i never had to with my 9500pro
GL HF
