95 for Antech 900?
hey I have a question or two about this case.
Can you fit an 9800gtx or 9800gx2 inside this easily? I know it is a mid tower case and was wondering about it.
I am thinking of purchasing one of these for a future build
Yes, either card will fit in the Antec Nine Hundred.
Are those HD cages in the newegg pic removeable ( where pci-e) card would go about?
yes, they are removable, but it's better to reposition them IMO. they'll fit in any 3 bays, but the 120mm fans mount to them. so if you totally remove them, you'll have to mod something to keep fans in the front (as i'm planning), or satisfy yourself with fewer fans. i have my two in the top 3 and bottom 3 bay positions ATM, and there would be plenty of room for a very long graphics card in one of the top two expansion slot positions. not sure about space for dual cards, though.
