alluro said:well i have never overclocked before and im not sure if i will doesnt it mess your cpu up after a while..
oh and what are some things or programs i need free if possible to get started...
Epicenter said:You will pay for getting Socket 754, as you will be unable to upgrade the CPU shortly, as AMD has relegated the socket to budget chips, mostly Sempron. Athlon 64s will not continue to come out for this socket. For not much more at all, you can get a Socket 939 setup. e.g. an NForce 4 Chaintech VNF4/Ultra board for ~$90 and a 3000+ Winchester 939 CPU for $150, for a grand total around $240. (NewEgg.com prices.) Now that's a good deal. And you'll be able to upgrade the CPU all the way to a dual-core chip if you are so inclined, and 939 will be upgrade-viable through 2007.![]()
(cf)Eclipse said:you mean the neo, not neo2
also, i believe lancaster has already been declared as 'turion'... the spot where is used to be on the roadmap has been replaced with turion, but newark still exists as the DTR equivilent. here's to hoping it's not based off the lancaster![]()
(cf)Eclipse said:it would be awesome. i'm.. really hoping it is.
and i pointed that out because the way you worded your post made me question, even though i know you should know
carnitine: amd seems to be doing almost everything in their power to prevent turion from working in desktop motherboards. i talked to a guy who does pcb testing for msi. he managed to get some turion samples, and he cannot get the turion to post in the k8n neo, despite the fact that they're working on the bios to try to fix the problems.
(cf)Eclipse said:that would make me angry.. though it's possible. i don't think they'd actually go to such measures though![]()
(cf)Eclipse said:just noticed, you should fix your sig on dfi-street
says you got your ram at 275mhz with 3.2v
but back on topic (or not), yeah. i posted elsewhere that if people want to use the dfi and turion together to PM me. i'll repeat
If you want to use the DFI lanparty nf3-UT with a Turion, please PM me
