939 block??
mode
just wondering, what is the best 939 block out there?
i have an amd fx-60
looks nice. ill keep it in mind
im getting a double rad for the moment. i will only be cooling my cpu (MAYBE i will add gpu in the future) would that be enough or should i go triple?
Most blocks come with universal mounting schemes these days so you could get something like the Dtek Fuzion, which is one of the best performing blocks you can buy today.
Do you OC your chip and what vid card are you running? I think if you can fit the triple you might as well go for it and leave yourself the headroom.
havent OC'ed it yet (i will once i watercool)
my budget is about 300$
i have a 7900 gs
i just bought a coolmaster 830 so space is no issue
