Ludic said:I'm still playing around with it, but there are things about 6500K I like, and some things with 9300K that I like. I'm not sure which I'm going to stick with. But does anyone know if it decreases the life of your monitor if you use the 9300K?
johto said:You havent said if you have CRT or LCD...i would think using lower temp color will save CRT RGB guns little...but remember to re-calibrate your gamma(pc uses 2.5) after you play with
the temps.
This is nice place for adjusting brightness levels (gamma)
Just pick 2.5 from the left column and then adjust brightness so that the bars are mostly just gray and not colored.
Ludic said:I have an LCD (Viewsonic 20.1" VP201s). It's listed in my sig, but I realize not everyone has sigs enabled. Will that program work for LCD's as well?
unearth01 said:I use a CRT The 930sb
I run at 7500K becosue its easier on the eyes and whites are so dahm white
dmonkey said:How do you set 6500K on a Dell 2005FPW?
dmonkey said:Besides the obvious, the OSD doesn't have specific settings for color temperature, just increments for red, green, and blue, as well as a red and blue preset.
If you could be more in depth, perhaps?
johto said:I then calibrated my adobe gamma to 6500K too. Its funny how fast my eye adjusted back to 6500K. It took under one hour. Now everything looks much better, less eye strain and colors are way more natural as they seem more warmer(pictures and movies). Switch today !![]()
Pulsar said:After reading this thread, I switched my monitors from 9300k to 6500k. Took some time to get used to as I've been using 9300k for as long as I've had these monitors. I switched back to 9300K for reference after I got used to it and found it to be "dead" in terms of color. Things appeared too pale and lacking any sort of warmth. I also found out that 6500k matches my print outputs completely, eliminating the need for guess work when trying to print a color image out. Thanks for the info![]()
