I am planning to build a new comp and have now narrowed down my list of cpu's to either a 930 or a 805. I am planning to overclock it to the best of my abilities using air cooling only.
I am thinking of an Abit AW8 to go with the 930 and an Asus P5WD2 for the 805.
which do you think you would better as the cost differential is only 10 pounds.
Also I am located in the UK so please don;t give me links to newegg telling me its cheaper to get it from there.
I am also thinking of using a Zalman CNPS-7700-CU cooler in place of the stock ones. Do any of you know whether it will fit onto the 2 above mobo? THe link at zalman is out of date and I don;t want to get everythign and hten have the hassle of having ot return the cooler due ot it being too big. (I know that its a different topic but I thought I would save from opening a new thread in the cooling section). My case would be a Antec SLK3800B UK black midi case with the included 400w smart power psu.
is there enough clearance in the case and the both mobo for the zalman cooler and which cpu is the better one...
please help
please help
