Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
None that I know of, you'll more than likely end up using a 80mm rad and adapting it to your 92mm exhaust port. Try taking some measurements to see if a 120mm will fit and adapting it to your exhaust.That may work also.
I'm with Bio-Hazard... I have never seen one before you posted that link dzitzner. Excelent find. Nice to know that they exist. Now to find a use for one...
