92mm push 120mm fan configuration.
Santasballz
i am thinking of doing this for my small form factor.
a 120mm pulling air out of case while a 92mm fan is pushing air out of the case.
my question is...would this impede performance of the 120mm fan?
for instance:
120mm pulls 60cfm
92mm pulls 30cfm
would it be the case that since the 92mm only pushes out 30cfm, the 120mm would only be able to pull 30cfm as well...thus decreasing performance?
it all comes down to...which performs better? 92mm push 120mm pull or just 1 120mm fan? (i don't care about noise)
No, it just means your case would have positive air pressure. Most people dont recommend this as it can create more dust in your system, most people recommended negative air pressive (using high cfm exhuast than intakes).
Cant say ive ever noticed much difference myself though.
sorry i am not sure what the "no" refers to. could you be more specific, "no" to which question?
No, it wont impeed the performance of the 120mm fan, it should still push its rated airflow, just creates positives air pressure due to more air coming in than going out.
Did you say this right? You're referring to both fans as exhaust?
If not, and you meant one is intake and one is exhaust as DarkBahamut took it, then yes, the two fans will have an effect on each other's performance. Its likely that somewhere between 30-60 cubic feet of air will pass through your case per minute. What this number is depends on the characteristics of each fan and the characteristics of the case's airflow.
edit: If 30 cubic feet of air enter the case and 60 cubic feet of air exit for one hour, your case defies the laws of physics. The fans will have a small impact on the pressure inside your case, but they won't create a vacuum.
