92mm enermax fan?
Arti
http://www.sidewindercomputers.com/92clearulwit1.html
The specs look great, but I'm not sure they're entirely accurate. Does anybody know anything about these fans? I'm a bit suspicious because it pushes more air than a Panaflo at a lower dBA and I've known Panaflo to be one of the best quiet fan manufacturers.
The model number is UC-9FAB.
i have that fan on my heatsink(sp-94) for my p4. it runs great but it does seem a little louder than they claim. not by much though. its a great fan.
I see newegg only has the 90mm enermax fan, will that work on my SLK-900U? If a 92mm fits, I sure as hell hope a fan 2mm smaller would fit.
Sound is always a subjective arrangement. Sure that particular fan could blow more air with less noise...if you were measureing noise from 10 feet away. No one goes by any standards in that industry so everyone's noise levels depend on how they test. At this point I would think that Panaflo fans have established the relative bar for noise/performance levels.
not sure about panaflow, but I sell the enermax's and they're all-around great fans. I wouldn't claim that they flow the highest cfm or are the quietest running, but it's still an all-around great fan. Specifically the 120mm's.
