- Apr 28, 2005
Has anyone here ever come across a 92mm ducting Mod similar to this thermaltake 80mm one
Copenhagen69 said:http://www.mnpctech.com/FanDuct.html
link to the plastic fan duct like in first post....
Copenhagen69 said:http://www.casecooler.com/evairdua.html
something like this?
actually you can see there is plastic around the mesh (from a cdr spindle) for the air to be tunneled, so the filter idea should work.Mr. K6 said:...If you use a basket like jwill did, the fan will start sucking air in through the holes and very little through the filter, so bad idea there too.
Autochthon said:Has anyone here ever come across a 92mm ducting Mod similar to this thermaltake 80mm one
Ice Czar said:first time I saw one was about 2001
about the time I joined the forum
reinventing the wheel is a very popular pastime![]()
Ice Czar said:--------------------------------------------------------------------------------------------------------------------------------
boning up on Fans might be helpful as well
its not just the airflow that is important, but the static pressure
a supply with a greater resistance will benefit from a higher static pressure
Air Flow Vs. Pressure Characteristics
Parallel & Series Operation
Stall of Axial Flow Fans
Basic Fan Laws
How to measure Airflow vs Pressure
How to Achieve Low Noise
Accoustic Noise
EMI
Introduction: Forced Convection Cooling
How to select the right fan or blower
Step 1: The Total Cooling Requirements
Step 2: Total System Resistance / System Characteristic Curve
Step 3: System Operating Point
there are three basic components to any thermal solution:
the heat transfer interface
(in this case the heatsink\waterblock total area)
the heat transfer medium's volume\pressure to time
(in this case for airflow, with additional variables like airflow resistance
w\ water flowrate and additional variables like turbulence, jet impingement)
and the temperature differential
(where using a cooler fluid air or water has a huge impact)
a real good computer oriented guide to thermodynamics
General Heat Transfer Guide
Heat transfer is all about temperature differentials. Conduction through materials and convection away from surfaces is proportional to the temperature differential that exists. Basically the thermal resistance of a given solution changes with the temperature differential, which is why thermal solutions are rated in °C/W which leaves that variable ambient open but gives you a formula
The heat transfer through the wall follows a simple equation:
Q=k/L(T1-T2)
We can draw some interesting conclusions from this equation. First, heat transfer is proportional to the temperature difference on the object. If the temperature differential doubles, the heat transferred doubles. Second, the conduction coefficient "k" is proportional to heat transfer. If the conduction coefficient doubles, the heat transfer doubles Alternatively, for the same differential temperature, twice as much heat may be transferred. The final observation is "L". As thickness increases, heat transfer decreases. Alternatively, to maintain the same heat transfer through a material twice as thick requires twice the temperature differential.
while that addresses conductance, there is a corrallary for convection (transfer from the heatsink to a fluid (air\water\ect)
its known as Newton's Law of Cooling
Autochthon said:thx great reads Ice even if those engineer's can't spellIt formalized a lot of idea's I'd taken for granted. I fear that common sense and trial and error will end up being my method. Too many variables for me to calulate. I suppose I should at least test if the case is under positive pressure. I have 3 .36A 80mm panaflos in parallel on the intake side and a .1A 60mm, .2 A 92 mm and 80mm PSU fan on the outlet side. Don' thave CFM's on any of them though.
My biggest issue is that I don't want to take the simple and most efficent path and just cut a hole in the side of the case; as a result I make all kinds of trouble for myself![]()
