92mm case fan suggestions?
flyingturtle
I'm looking to buy 92mm case fan. Both are for Antec cases. One is a P150 case that can support two 92mm fans in the front, but I think I'll just use one fan to cool the hard drives.
Any particular brands or models I should look at?
I looked at newegg and there were many choices. I guess I want something that is well balanced so it won't make much of noise. I'll be using 5-6v on the fan (via the bios) to make them quiet so they won't be running at full speed.
Thanks in advance.
Personally I like Arctic Cooling fans... they're really quiet and good quality.
If you can I'd recommend using an open cased fan for maximum airflow (like Arctic Fan 9L).
