Is Intel new 925x (alderwood) in it for the long run, will it be able to run Intel futur 64-bit proc? Also is it safe to go with the 925x then the 915p? Also what is the major difference? Also which is currently the best 925x motherboard?
I don't know on the 64bit, I would hope so since its their new platform. Since its first generation and Intel loves to change all the time, I'd skip it for now. Here's something that might help you with "which one" if you do get one: http://www.tweaktown.com/document.php?dType=article&dId=690
