I guess my main question is; where are everyone's temps coming from. I see lots of reviews that might say "core temperature" but don't actually say what program their numbers are from.
Anyone else with the 920 note that Speedfan reads the core temps way lower than HWMonitor/Coretemp/TrueTemp? I've seen lots of screenshots that just show the "CPU" number from the DFI Lanparty utility. That reads reads about 30c lower than the HWMonitor Number on my setup and as far as I can tell it's just a thermistor on the motherboard.
I've reseated this v10 probably 6 times; I've tried spreading Arctic Silver, The Line Method (per A.S. instructions). Even at just 1.25v (3.8ghz) I can still push to 100c at 100% Utilization in a cool room. It has never become unstable; I've always stopped Prime95 in the 90s but I've let it spend a lot of time in the mid 90s.
I'm just wondering if the numbers coming out of CoreTemp/HWMonitor Ect are reliable? If I was going by Lanparty or Speedfan I suppose I would think everything was just fine. When my gtx275 is running 90c the air coming out will just about burn you but air coming out of the v10 is pretty much luke warm; It sure seems like it's an issue with the CPU/Heatsink junction.
I set the CPU on top of the heatsink once and tried to look between them and I was able to see a tiny tiny sliver of daylight; I wonder if I should lap this thing; like the base is concave - or the cpu is? It's got a mirror finish so I hesitate to do anything to it. Neither the cpu or heatsink have any blemishes at all.
Sorry; just kind of bummed out; I ran it at 4.2ghz out of the box but I've been progressively lowering clocks and vcore to try and get temperature under control and it just seems like BS considering the v10 is beating out every other aircooled solution on the market according to every review I've seen.
