915 MOBOs
demetrics
I have a couple of basic questions. First I want to know if there is a difference in the ATA 100 and ATA133. I mean if you were into Multimedia/Video Editing will it show a difference? Second, I read a Review:
"Just received a Intel195 chipset motherboard which is ATX and a new ATX powersupply. However, it went un-noted that all i915 chipset MB's require a 24 pin ATX power cord, while most other chipsets require a standard 20 pin ATX power cord. Therefore I have order a power wire adapter and wait longer to get my new computer finished. This is just a pre-cautionary note for those who will also run into this problem. Adapter costs $xxxx dollars, so pretty cheap. "
Does anybody have these 915 MOBOs is it true that you have to buy an adaptor?
not really, and yes u do, and those adapters probably will not even give you enough power if you overclock. 24 atx is going to be the new standard with the 6 pin pci-x(or e) connectors.
