did you already buy an antec 900? if you didn't i would pick another case. i own the 900 and it really isn't that great. cooling is great, but it collects dust, and cabling is a bitch.
Dust comes from the air.
The CM 690 looks llike a great case. The cost would be almost $54.00 more than the 900 case I can get. Maybe a little dust isn't so bad?
Tricky0502 are your fans running on high speed or low?
GJSNeptune anything that lets me procrastinate is a good thing.![]()
The only kind of fan filters I am finding are ones that bolt up using the fan mounting screws. Cleaning those could be a real pain.
Canned air works well enough. No need to take it downstairs.
i run all of my fans on low. i cant stand the noise if i turn them up.
True. I usually get the vacuum cleaner out and have it on while I use canned air.
Just be careful, don't get it too close to computer components. The friction with the air and the plastic nozzle of vaccuums builds up enough static to fry electronics.Hadn't thought about doing that. Good idea.
where did u find the 900 for $79 with FS?
