90* molex conectors
I don't have a clue. I tried going to an electronics shop locally and they can't even get a part number from Molex.
OK, I'm thinking this needs to be put in the FAQ.
Directron doesn't sell 90 degree connectors by themselves, but they do sell a T-power adapter that has one normal molex, TWO 90 degree pass-throughs, and ONE 90 degree end cap, and it's dirt cheap.
So, buy this, and you have three choices:
1) Use it as is. Plug it into your PSU and your devices.
2) Cut the wires, solder in new lengthes (or shorten it) and go.
3) Pop the connectors off of their original wires and add them to your PSU wires.
They have a special on 2 adapters, makes 'em $2.00 each. I bought these and poped the connectors off to make my own custom wire lengths.
Here's my real question. Where can I find both the male and female ends of these molex connectors?
James
Edit * . I really should have looked around the posted sites before I said this =) Directorn has both pieces.
