90 Degree WALL outlet?
NewShockerGuy
Do they make a wall plug that is 90 degrees?
IE: You have your standard wall jack for power that is facing straight... do they make an adaptor that goes into it and then has the power at the bottom... Think of an "7" almost in shape.
*Side topic what happened to the Search button?
Thanks,
-Nigel
I only need this for a single outlet...
Sort of like this but I only need one and preferably be able to aim it almost straight down...
-Nigel
Look for a replacement power cord for a refigerator, they are very "flat" and the wire exits the part that plugs in the wall at 90 deg (heading down towards the floor) you will of course have to replace the existing cord with the new one. Lowes Homedepot Ace hardware or an appliance repair shop.
http://www.skycraftsurplus.com/index.asp?PageAction=VIEWPROD&ProdID=1076
I have seen them even "flatter". the one on my fridge sticks out only about 3/8 inch. but I could not find online.
http://www.worldofcables.com/oscatalog/CreateHTMLPagesItem/PWR-PSLIB-4-6PK.htm
http://www.google.com/search?q=power+cord+flat&hl=en&start=10&sa=N
