FSB Frequency: 210 Mhz
Memory Frequency: 100%
Resulting Frequency 210 Mhz (who would have thought....)
T(RAS): 5
T(RCD): 2
T(RP): 2
CAS: 2.5
AGP Frequency: 66 Mhz
AGP Voltage: 1.5V
DIMM Voltage: 2.77V
Resulting OC: AMD Athlong XP 3200+ (2.310 Ghz)
Resulting Temps (idle): 43C/109F
Haven't tested for stability using Prime95, but the board posts perfectly. Is this too much, just right, or not enough?
EDIT:
btw, here is the hardware I'm using:
CPU: AMD 2500+ Barton
PS: Generic 400w (lines are incredible... only 0.1-0.3V away from what the line is rated at)
HSF: TT SilentBoost
RAM: 2x256 PC3200 Buffalo
T(RAS): 5
T(RCD): 2
T(RP): 2
CAS: 2.5
AGP Voltage: 1.5V
DIMM Voltage: 2.77V
EDIT:
HSF: TT SilentBoost
