8rda+ clarrifications. Thanks (NB STepping etc)
ffactoryxx
Well i havent messed with my computer much since a few months back.
As of now im running
8rda+
2100+ @ 2.3ghz 11.5x200 1.72-1.75v
512mb twinmos pc3200 2.77 v ch-5 chips
6800nu
Now my question is this. I have 5 case fans and its pretty cool in my case and never really had any problems accept in the summer when my temp guage went over 50c games sounds would crackle. Reboot fixed that plus that only when it was so hot i was sweating. Nver gets over 43-45c now underload and winter is coming
Anyway. CPU-z and cpuid both say i have a C1 stepping. Are both those probrams 100% accurate on that or can they be wrong????? I never removed the northbridge hs and dont think i will. Why touch it if eveything is fine. The wierd part is that is doesnt get hot after using, not even warm most of the time. Whats going on? Also do you think ill be able to raise my fsb more if cpu-z is correct??? This isnt an officail 400fsb board anf i got it at new egg in April 2003. Just dont want to blow anything out
try raising it. Mine (also a C1) runs at 225 with the stock heatsink (and using stock voltage. Wouldn't get higher even with the max voltage). I backed it down to 217 and it runs without any problems. Memtest showed that my ram was giving me errors at 225 also (yet my system never crashed) so you should use that also.
did you take off your nb to check the stepping? Or use cpuz. Just didnt know how accurate it was. Whats your chip and multiplier
Didn't take off the Northbridge. It is the last version of the 8RDA+ (ver 2 or 2.1 or something, I forgot). Using a Barton at 217MHz with a 8 multiplier usually (1736) but it is stable up to a 11 multiplier (with those conditions. Probably even higher mulitpliers if I lower the FSB)
