8pin from 6pin rig
Sathsayin
a 6 pin pci-e plug provides 75 watts to the card, but an 8 pin provides 150. strange thing is, those two extra pins are just grounds. i wanted two 8 pin pci-e connectors so i could use overdrive in CCC, but this psu only has one (6+2=8). so i got a molex plug, took out the red and yellow wires so only two grounds were left, and rigged that up to my second video card, in addition to the 6 pin plug. essentially, i made my own 8 pin connector. works great! overdrive enabled
Saw this on newegg.com reveiw of the
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16817611007
Don't know anything about that psu so....
Was just wondering what are the dangers drawbacks etc...
Thanks just curious nothing more.
$50.00 for 50 amps....too cheap? Not familiar with that unit either.
as to your other question look here
http://www.hardforum.com/showthread.php?t=1385080
Luck man, maybe Paul da Mod can help you on the PSU;)
oh I wasn't looking at that psu i got an antec 380 watt earthwatts. I was just curious to the drawbacks after i had seen this on newegg.com thanks for the link!
