8mb Savage XI running cod - possible
G66
ok, it sound crazy I know the specs for the game. I wondered I there was some kind of program that forces games which require Hardware Tnl to run without (get it...)
I put this thread elsewhere and was booed at by techies... (though I'm sure it possible)
No its not possible.
What you are asking is the same as lets say trying to trick a game that needs a DVD drive to install to use a CD drive. Even if there were a way it would run like garbage.
If you have a pc enthusiast friend they ussually posses boxes of "junk parts". More than likely his box will contain something that could help you. I mean hardware TnL is from like the original geforce isnt it? maybe the geforce 256.
Geforce2 GTS introduced this method of shading.
as crazy as it is, it honestly is worthless, your speed in that game will be so slow you'll just want to cry if you perform software rendering
You are incorrect. The GeForce 256 was the first true GPU. It is about as far away from the current GPUs as you can get and still be in the same class of processor, but it was an actual GPU.
I agree about software rendering. It's crap. It looks bad and it performs badly. That is why we have GPUs to begin with: because software rendering could no longer cut the mustard.
Yeah it was a geforce. I gave my old geforce DDR away and someone actually used it to play through Far Cry !!!
8mb savage has no chance of running any modern game.
kidin that thing ran FC...
Also I only want the software to run the editor... I want to edit levels and make mods on my laptop with the radiant and then transfer them to my main pc.
I know I couldn't believe it. It didn't meet minimum requirements but it still worked since it's got the same features, albeit with even less power than a geforce 2,
which was supported. But he beat the game start to finish with a geforce 32mb DDR.
640x480 Looooow settings and very erratic frame rates. The water was so ugly. LOL
on older laptops, software rendering is greater performance to watever it has asa a video card
btw ther's a program called 3d analyze that emulates tnl
"3D-Analyze is to tool for transform and lightning hardware emulation. I know it is very useful for running TnL games on video cards that have not on board dedicated circuits for TnL calculations (like all Voodoo, Kyro, Radeon loads and older). It uses power of central processing unit to I give emulation."
yea my friend beat farcry and hl2 on a mx440
320x240 goodness!
so 3d analyze emulate 3d tnl but what bout the actual hard ware I mean it can't actually emulate the physical shaders can it...
+ can't believe that mx440 ran HL2... 320 x 240 eh
tried that swiftshader thing works on lots of games (quite good too) but COD is an open GL game so it doesn't work with it. If only there was something that was the same as that except did open gl as well...
