8gbs Too Slow
HK-Viper1-
Hi all,
I need help tweaking or fixing my memory.I recently added 4 more gigs to my MB filling all the slots (4 2gb modules). They are all the same and it has slowed my pc down. The timings were set to 5-5-5-15 for the first 2 modules when I originally installed them and I did not do any timings for the second set. I do not know if I have to make any timing adjustments for the 2 new sets that I recently added and I am assuming that if the first 2 were set then so will the second set but I maybe wrong. I notice the slow down when I am gaming and or using PS CS4 64bit or 32bit. Here is a pic of Everest showing my current configuration and see my sig for syst info..
Thanks for all who can help.... \\Viper
Make sure you are running your ram at the correct voltage. Most bios default to 1.8v. My G.Skill ram requires 2.1v. It's also possible Superfetch is utilizing the additional memory, and your system will stabilize after Superfetch is finished. Keep us posted.
