890fxa blinking "FF"
Irishllama
So, as I was transplanting my system into it's new case all went fine, until it was time to boot.
Now the 890 is blinking "FF" as well as the HD activity light blinking.
I've tried:
Resetting CMOS
Removing Video Card/HD/Ram
Re-seating CPU.
Hell, I've even tried a different X6.
Still blinking FF. I'm going to go ahead and say some how the board has died in between the 45 minutes of different cases. I figured I'd try here first.
iF u put it back ya think it'll start working again?
Think possitive, check jumpers, switches, wire routing, anything else you can think of...
CPU is dead I think.
Mobo killed it. If I recall, my 790FX cooked my Phenom II 955 and gave me that error. MSi and AMD replaced both for me.
I am like 98% sure that was the error I got when the board killed itself and the cpu.
Way I tested was I put another cpu into the mobo....and it killed that cpu too. Costly way to be 100% sure. AMD was kind enough to replace that cpu for me too :)
Oh damn, you broke it.
Anyways, did you try taking the motherboard out of the case and see if it boots like that. I had a similar issue and turned out be an unnecessary standoff touching the back of the motherboard.
^totally agree with this! i bet a dollar this is the problem. happened to me once and to my buddy once.
Yep, I tried taking it out of the case. Made no difference, still just says "FF".
Irishllama,
I sent you several PM.
I still didn't get the package you sent two weeks ago. Please PM me the UPS tracking number, so I don't have to track you around the forum.
Thanks.
Irishllama,
Thanks.
Odd, it didn't pop up.
As soon as I can get the hard drive into a new PC i'll send you the #.
