88c... can this be right?
tempoct
My CPU is currently reported by Asus PCProbe that it is 88c... way too hot!
However, TAT reports 2 cores temp at 55 and 51c... Speedfan reports the same thing as Asus Probe.
Usually, temp of all the program are pretty close. Suddenly, the PCProbe/Speedfan jump the temp but not TAT. Of course, I'd like to believe in TAT more, so I let it run.
This happen to me before, the problem is gone when restarted.
Here's component of my rig;
E6300 @ 1.35v (3.29GHz)
Asus P5B Deluxe Wifi (470 all stock voltage)
Corsair XMS2 6400C4 (promos @ 470MHz, 5-5-5-18, this is tested to DDR2-1000)
It runs @ 88c for a while now. I test stability using dual prime95 now. The temp were close but Asus probe just jump the temp about 1 hr ago. It has been run almost 6 hrs now. Everything is fine and stable, except when the CPU temp jump in Probe, all my fans in the case has rev up to full speed.
Might be a bad senors. Id just look at tat since core temps are more important.
